Pedal play
Old Nov 14, 2006 | 11:14 PM
WS6FTW's Avatar
Default Pedal play
So the is car back together, and now the clutch is acting up. When I picked the car up, it was disengaging at the floor with an easy two inches of free play at the top. I went back inside, and was like did you even bleed this? They "re-bleed" it and got a lot of air out of the line, but I think there could more still in there. The clutch doesn't have too many miles on it, I put it in the car in Feburary and a new slave cyliner. It engages at the bottom, and loses pedal pressure frequently. The clutch is a CF DF. Is my slave cyliner bad, or is the master going out? I can't get on the car and shift quick b/c it disenegages right on the floor when I do that. Any help would be greatly appreciated.
Old Nov 15, 2006 | 01:33 AM
JTSLP559's Avatar
same thing thats going on with my car... it did that. it got worse over time. theres play in mine to. i spent hours bleeding it. i went through about 15 reservoirs to. i always looks pressure. i have to pump it constantly. i cant really pinpoint whether its the slave or master.. im leaning toward the slave. im replacing mine this weekend. so i will let you know if that fixes it. if i forget to reply back by monday send me a pm an il let you know!
