Clutch Question
Old Nov 17, 2006 | 03:55 PM
blackbird95's Avatar
Default Clutch Question
Okay hopefully you guys can help me. I've got the stock clutch in my 2002 WS6. I've been noticing recently the clutch seems to have a little bit of play in it before it engages, but it doesn't have play it in all the time. Sometimes it will feel just like it did when I bought it. And it's not slipping or anything like that. Any ideas on what's going on?
Old Nov 17, 2006 | 04:30 PM
Sonic28's Avatar
Sounds like some type of hydraulic problem; master cylinder and/or slave cylinder. I would do the easy thing first; bleed the system. Then drive it for a couple of days. If it gets worse, or happens again, I would look at one of the other hydraulic components. Good luck.
