LS7 clutch
Old Nov 22, 2006 | 11:59 AM
Sartobuilt's Avatar
Default LS7 clutch
Installed a LS7 clutch. Dynoed 415 rwhp 408 tq.
2000 mi. on it. Went to the track chirped all gears on first pass. Degraded every pass after that.
The clutch still holds on the street unless I try power shifting into 2nd gear. then the clutch goes away.
What is my next best choice for a clutch?
Old Nov 22, 2006 | 03:13 PM
blueovalbeater's Avatar
Sounds more like you are having air problems in the clutch system. Give it a good blead and see what it does. 415 rwhp shouldnt be to much unless you really abused it at the track with a 6000 rpm clutch dump, or slipped it and glazed it over.
Old Nov 22, 2006 | 05:54 PM
MeentSS02's Avatar
Kleeborp the Moderator™
To me, it sounds about right. Even in the ZO6 it was designed for, people complained about them degrading after some hot lapping.
I've been happy with my RPS clutch, but there are a lot of people that aren't. I'd say you should go with the Textralia...tried and true, and should hold your abuse with no problems. Yeah, it isn't cheap, but then again, you are replacing an LS7 you installed not too long ago...
Old Nov 22, 2006 | 08:44 PM
Sartobuilt's Avatar
Yea Im leaning twards the textralia.
Old Nov 22, 2006 | 09:21 PM
Yes true. Man I love you textrallia guys. I am not going to start an argument here but alot of people dont have a grand, to drop on a clutch. But if you do, the textrallia will exceed any clutch on the market. But my thoughts are if you are not pushing the envelope on power the LS7 will be a wonderful clutch.
I just installed my clutch and im around the 39x rwhp mark, if I do have Problems with it, I will put in a tex.
Old Nov 22, 2006 | 09:23 PM
SladeX's Avatar
Stock clutches and hot lapping don't mix.
Old Nov 22, 2006 | 10:10 PM
Sartobuilt's Avatar
I wasent even hot laping it.
Old Nov 22, 2006 | 10:16 PM
MeentSS02's Avatar
What's your race weight and gearing?
Old Nov 23, 2006 | 03:13 AM
evilbadz's Avatar
I took my LS7 for about 4 runs total one HOT night, with probably a 5-10m cool down between each run. Chirped 3rd every pass on MTs, and didn't have any problems. Still runs great to this day. Maybe something wrong with yours?
Old Nov 23, 2006 | 03:28 AM
minesfaster's Avatar
I just ordered my ls7 clutch kit for my ls1. I hope i dont have these issues. I only have around 360 rwhp. What do you guys think ?
Old Nov 23, 2006 | 11:50 AM
Sartobuilt's Avatar
Stock gears and trim. Probably 3400lbs. or so.
Ill check it out when I install the textralia. Im not messing around any more with clutches.
Im gonna put a rearend in it this winter anyways.
Then I can get some slicks and drop the hammer on it! See what it will really run.
Old Nov 23, 2006 | 12:07 PM
evilbadz's Avatar
I have more than that (hp wise) and had 0 troubles running mine down the track time after time.
Old Nov 23, 2006 | 04:09 PM
The PAT WS6's Avatar
wat exactly is the clutch doing? i just ordered mine and i dont wanan regret it.
Old Nov 23, 2006 | 08:16 PM
Sartobuilt's Avatar
I dosen't feel consistant. Some times it grabs and some times it dont. I have to make a good solid shift and no slipping the clutch.
I think im gonna try bleeding it this weekend and see if that helps.
I am running some big nittos so it dose hook up good.
The other nite I was runnin 55mph 2500 rpm 4th gear , downshifted into 3rd and lit the tires for a good 30 ft. Tried it tonite and the clutch went away.
I think I am hard on a clutch, so I hope the Tex holds up.
Old Nov 23, 2006 | 09:08 PM
just1news6's Avatar
hydrolics bleed or change same thing happened to me first pass hard all gears then second pass went for 3rd and it wouldnt go in bleed it i bet it will fix it or upgrade the hydros like i did
Old Nov 24, 2006 | 03:43 PM
Thanks for the info guys. Hopfully the other guys juet need to bleed or get new hydros. Good luck ordering your clutch this time of year. Ups has had mine for 2 weeks now.
Old Nov 24, 2006 | 06:33 PM
vince3's Avatar
i have one in my z06 H/C with the
same power as you, i think this clutch hurts dyno numbers
Old Nov 24, 2006 | 06:41 PM
MeentSS02's Avatar
Seems like people have the same issue with this clutch as they do with the RPS...they just don't like to be launched very hard (at least with any consistency). Hopefully the 4.11s I have now will fix this problem before it starts by making it easier for the motor to get the car moving...
Old Nov 24, 2006 | 11:35 PM
So is that the main problem with the ls7 clutch ? SO far.
Old Nov 26, 2006 | 07:31 PM
evilbadz's Avatar
I still think it must just be some people. I accidently (yeah my first time driving a M6 at the track ) dumped the clutch at about 3500 RPM with 4.11s and near 400hp. The car didn't like it, but the clutch held up strong.
