clutch master pre bled?
Old Nov 27, 2006 | 04:43 PM
ElChiefWS602's Avatar
Default clutch master pre bled?
Just got my new clutch master in today. Came complete with new resevoir and slave line. Also it is already filled with fluid. Is that normal? Does this mean I have to bleed it still.
Old Nov 27, 2006 | 08:22 PM
MrEddie's Avatar
Yeah, mine is full with fluid as well. I imagine it's bled pretty well, but I'm going to bleed it again just to be sure. Plus, when you crack the bleeder on the slave to snap on the master, it can ingest some air down in the slave and work its way around.
Old Nov 28, 2006 | 04:42 PM
well I planned on bleeding the entire assembly once I get it back together. I was more concerned with bench bleeding first. Anyone else?
Old Nov 30, 2006 | 01:47 AM
BigDB's Avatar
I dunno but I just gravity bleed my system after my drill mod.
Old Nov 30, 2006 | 01:35 PM
autotrix's Avatar
Closed ex-Sponsor Account
Bench bleeding is messy, but in the long run, can save you alot of time and or headaches!
