3rd gear grinding?????
Old Jul 29, 2002 | 09:39 AM
BriguyLS1's Avatar
Default 3rd gear grinding?????
I have a problem i just bought a 98 trans am with 40,000 miles on it and (sometimes) when you put it in 3rd gear it grinds and doesnt want you to put it in it. Is this a sincro problem?? it also only happeneds if you are easy on it and not going that fast.
Old Aug 1, 2002 | 08:16 PM
2bseen's Avatar
11 Second Truck Club
Default Re: 3rd gear grinding?????
could be a bent fork.
Old Aug 2, 2002 | 07:45 PM
Navy David SS's Avatar
Could, maybe both.
Going through the same thing right now. Except mine was done at the track <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" />
Is 3rd gear find while granny shift? WOT ?
If while granny shifting could be either the 3rd-4th fork or syncros. Only a good tranny shop that can tear it apart will know.
If it is grinding while WOT, it could just need the 'drill-out' mod. www.installuniversity.com has a great write-up about it.
How is your clutch? When was it changed out?
A 98 with 40K on it, you know it has been beaten a little.
David
Old Aug 5, 2002 | 11:53 PM
BriguyLS1's Avatar
thanx for your help its real weird when i get on the gas it tends to go in good and when i am just goin slow and take it easy on it then it tends to grind and kick you out of it...?? you think it is a bent fork? if so.. how much you think it will be to repair and who should i take it to?
Old Aug 5, 2002 | 11:57 PM
BriguyLS1's Avatar
my car has only 42,000 miles on it and its a 98' i dont think the clutch has been changed out i just bought it with 40,000
