Can not down shift into 2nd anymore?
Old Nov 29, 2006 | 09:32 PM
2000SS1979's Avatar
Default Can not down shift into 2nd anymore?
Just like the title says. This just happened to me a couple days ago. When i am driving and going through the gears it goes into 2nd fine. But if like I am slowing down for a corner and try to go from 4th to 2nd or 3rd to second it will not go into gear. But if I go from like 3rd to 1st then into 2nd it will work, or if I pump the pedal a few times it seems like it goes into 2nd then. I searched around for a bit on this particular problem and didnt find it.
Car specs:
year:2000
Miles:59,000
Everything on it is bone stock. Any thoughts would be appreciated.
Old Dec 1, 2006 | 07:55 PM
2000SS1979's Avatar
Bump for any suggestions.
Old Dec 1, 2006 | 08:19 PM
RoastEmSS's Avatar
same things happening to me, same year, same miles haha
Old Dec 1, 2006 | 09:32 PM
1998z28ss's Avatar
sounds like you need a bleed or even have a bad 2nd gear syncro. But I'd bleed first and see from there.
Old Dec 1, 2006 | 09:35 PM
2000LS1TA's Avatar
Old Dec 1, 2006 | 10:00 PM
KCFormula's Avatar
Bleed it. If its still bad I'd tell you to upgrade to a '01+ slave cyl.
Old Dec 2, 2006 | 07:28 AM
2000SS1979's Avatar
Well, I guess I will take those steps. Thanks for the help guys.
