Tranny oils
Old Dec 14, 2006 | 08:02 PM
smokeum99ta's Avatar
Default Tranny oils
I did a clutch job on a 2004 viper recently. And while working on it I noticed that it had a sticker on it to use "gear oil" (which type I don't remember). The viper had a T-56 trans. Why is it that GM says use dextron merc. III in the trans and Dodge says something different with the same trans ??????
Old Dec 14, 2006 | 09:39 PM
MeentSS02's Avatar
Kleeborp the Moderator™
I've heard internet rumors that the Viper guys like to use some stuff called Syntorq or something like that. From what I understand, it is a thick, "gear oil" type of transmission fluid that holds up better to the heat that is generated in that particular car. Not a lot of cooling airflow going around the transmission in that car due to tight packaging.
Take that information for what it is worth, as I certainly don't own a Viper, and have never used that type of oil in my T-56.
Old Dec 15, 2006 | 09:32 PM
What's funny about that is that i've heard that the latest fad is to use two quarts of the viper stuff and two quarts of GM's sycromesh. They claim the tranny shifts better than ever. I think i'm jumping on the banwagon with this one to see if there is a difference between what i'm using now.
Old Dec 15, 2006 | 11:22 PM
MeentSS02's Avatar
If you do it, post up the results.
