Driveshaft loop install
Old Dec 25, 2006 | 07:42 PM
The SSheriff's Avatar
Default Driveshaft loop install
Do you have to disconnect the driveshaft from the rear end or does it just loop over the driveshaft and clamp together?
Old Dec 25, 2006 | 09:38 PM
INMY01TA's Avatar
Depends which one you're talking about.
Old Dec 27, 2006 | 02:14 PM
badpewter-z's Avatar
LS1TECH Sponsor
most you have to , i know the lakewood installs w/o removing the drive shaft, only takes a few minutes to get the shaft out anyway though . either way its an easy job
