M6 Popping out of reverse.
Old Aug 14, 2002 | 03:02 PM
CamM's Avatar
Default M6 Popping out of reverse.
This past weekend I installed my RAM VDS w/ the 910 disk. I am having an issue when putting the car in reverse. When the car/transmission is cold, it constantly pops out of gear. After the car has been warmed up, no problems with reverse, also, no other gear is affected. I did lose some tranny fluid during its removal and replaced some but not sure if I put in enough. I've adjusted the clutch pedal up and down numerous times with the adjustable master, with no change on reverse. I had no issues with the transmission previously to the clutch install. Any ideas?
