bad shift fork
Old Jan 13, 2007 | 05:43 PM
styoung's Avatar
Default bad shift fork
i just bought a 2002 Z28 with a m6 and how can i tell if the 3-4 shift fork is bad? i would like to know so i can get it fixed before the warranty is over. thanks a lot
Old Jan 13, 2007 | 05:51 PM
ELDIABLO's Avatar
What does your trany do that makes you think its a bad fork?
Old Jan 13, 2007 | 06:01 PM
styoung's Avatar
i took it for a test drive for a little while and when i shifted into 3rd it made a raddle almost i cant exspane, i havent drive it enough, but only when i let the clutch out. im looking more for the warning signs of it going.
Old Jan 15, 2007 | 12:51 AM
Phlip00WS6's Avatar
Sounds like the clutch if it only does it when you let out of it..
Old Jan 15, 2007 | 08:54 AM
Specialized's Avatar
If when you let out the clutch and the shifter pops out of gear, you have a bent shift fork.
My 4th will not go in on high rpm shifts, it just grinds. Sometimes it will go in and then rocket out and hit my hand and it hurts.
