Clutch and adjustable master problems.
Old Aug 19, 2002 | 09:54 PM
ldickson's Avatar
Default Clutch and adjustable master problems.
I just installed the hay's clutch and the carteck adj master and I'm haveing some problems with it going to reverse.it go's into every other gear fine.do I need to adj the master some more?? have you guys had this problem before??
Old Aug 19, 2002 | 10:03 PM
Sears's Avatar
!Dial-up Director
Default Re: Clutch and adjustable master problems.
That is weird, try adjustaing the master cylinder rod out some more. How did you bleed the system?
Justin
Old Aug 19, 2002 | 10:50 PM
ldickson's Avatar
I did'nt but the guy's at the shop used the line going to the slave.They told me that it would get better with time but I wanted to see if anybody else had this problem before.It will go into revese but it's hard.
Old Aug 20, 2002 | 08:52 AM
ldickson's Avatar
I adjusted the master out some more and that did it thanks. <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" />
