Help 3rd gear pops out!
got those fixed yesterday and was driving around and it is still poping out
so whats the deal? what do i need to do to fix this deal?
For whatever reason, they thought it would be a good idea to make it out of aluminum. There is no way to fix it other than rebuilding the trans, or replacing it. Luckily, mine was under warranty, and I was able to get a brand new T-56 free of charge. I hope you have a warranty???!!!???
) Turns out (and I'm still embarrassed 8 months later...) that a while after I installed my Pro 5.0 shifter, the little bolts that serve as the bump stops backed themselves out by a few threads and were preventing the shifter from going all the way into gear.
I don't know if this is your problem or not, but it's worth a shot to check.
he had a hurt in his 64 chevelle waaaaaaaay back in teh day and said he had the same thing happen to him and wants me to find out how to adjust the linkage and the bump stops, so i think im going to try that before calling t56 rebuilds
Thanks,
Amber
T56Rebuilds.com
Transmission Jumps Out of 3rd Gear (Replace 3-4 Shift Fork, 3-4 Synchronizer Assembly, 3rd Gear Blocker Ring and 3rd Speed Gear) #01-07-29-003A
1999-2000 Chevrolet Camaro
1999-2000 Pontiac Firebird
with Manual Transmission (RPO MM6)
This bulletin is being revised due to a change in part numbers. Please discard Corporate Bulletin Number 01-07-29-003 (Section 07 - Transmission/Transaxle).
