Which Flywheel???
Old Jan 22, 2007 | 11:02 PM
SouthernSilverSpeed's Avatar
Default Which Flywheel???
I need to buy a flywheel badly! Someone please point me in the right direction. I bought a spec stage3+ clutch disc and pressure plate. What flywheel should I get?? Aluminum??? steel?? which brand?? opinions NOT needed just good advise
Old Jan 22, 2007 | 11:08 PM
Vintage Iron55's Avatar
How will you use this car? Drag race? Does it spin the tires out of the hole? With the DR's I would venture to say yes.
The light flywheel will allow the motor to rpm faster. The heavier flywheel will store more energy to leave hard but will punish you at the big end. If your car bogs off the line, the heavier one may help. If your car spins off the line, the light one will help at both ends.
Just the facts.
Henry
Old Jan 23, 2007 | 05:15 PM
well with the 4000 stall I had no traction problems what so ever.
How much bog down is present with an aluminum?? and is it a MAJORLY different pull on the top end compared to a steel one??
