shifting/clutch problems
Old Jan 24, 2007 | 10:55 PM
stevensLS1's Avatar
Default shifting/clutch problems
im really puzzled right now. i blew my clutch a while back installed a mcleod twin disk then an 00 slave. well my motor blew then the the shop told me my clutch was sticking and probably needed a new slave. so i said fine. they installed the adjustable master cylinder from mcleod. well it was running fine for a while now im having quite a bit of trouble getting into reverse and i feel some sloppy shifts. ( this problem was with the other master also) thanks guys!
Old Jan 25, 2007 | 12:05 AM
KW4life06's Avatar
ya im having the same problem. especially with getting into reverse and 1st. sometimes it goes well sometimes its real hard to do
Old Jan 25, 2007 | 12:50 AM
DONAIMIAN's Avatar
Id take it back to whoever did the work. Sounds like its air in the system.
