new clutch problems
Old Feb 1, 2007 | 10:27 PM
spgino's Avatar
Default new clutch problems
i just installed a new stock clutch after having a problem with the one that was installed in the summer.. i got it back and noticed that i had to pump it several times to get it in gear(air in the hydraulics) took it back and they bled it several times.. i got it back and it was better but occasionally ihave to pump it several times to put it in gear.. i also noticed the disengagement and engagement points are extremely close to the floor (about 1" off fully depressed)<-- is this normal cause it was never like that before??
thanks!!
Old Feb 1, 2007 | 11:09 PM
seawolf18's Avatar
I know the guys with the LS7 clutchs are expericeing low enguagment, but moves up to stock hight after they put some miles on it.
Old Feb 2, 2007 | 07:44 AM
Black_98Z's Avatar
like he said...it might just need to break in some or it might need to be bled again.
Old Feb 3, 2007 | 02:01 PM
spgino's Avatar
i replaced the slave when i installed a performance clutch the in the summer.. didnt opt to change it when the performance clutch blew up 3 months later and it was replaced with a stock LS1 clutch... master cylinder is still stock.. and i still have several inches of dead pedal feel, the clutch engages/disengages 1 inch off the floor even after several bleeds and breaking it in for 500 miles.. any help 'cause this is really annoying.
thanks
