T56 in a 70 gto
I would check with Wier hotrod products. They make a Bellhousing for Chevy's not sure if they have one for Pontiac of not. McLeod makes an adapter plate for chevy's which uses the existing LS1 bellhousing, again not sure if they make one for Pontiacs. I would check with both companies.
If the 400 Pontiac BB is the same bolt pattern as a SBC or BBC then an LT1 T56 will work. I have a 94 LT1 T56 bolted up to a 69 SBC. The only problem you might have is finding a clutch and flywheel to work.
