Car Wont Go Into Gear!!!! hey i currently bought a 99' z28 and i hadn't had a problem with it until out of a sudden the car at the stop light did not want to shift into any gear. just like the other post on top, when its off, i can shift it into gear but as soon as i turn it on, it starts to move forward. i stopped the car as soon as i got that problem and friends have told me i need a new clutch and master cylinder and slave.. clutch is a centerforce dual friction with less than 12,000 miles . what should i do????before spending any cash, what and how can i check my car??? any steps on bleeding the lines??? i would really appreciate ur help thanx people...let me know what u think |
Sounds like its your clutch. |
thats what it sound like clutch,thats what happen to my on the damn beltway |
Sounds like a clutch issue. I have replaced my clutch 3 times, each lasting 10 to 15k miles(spec stage 3). |
Give us a call. I can get you back on the road fast! |
i as well have replaced my clutch about 4 times,3 spec's 3,one stage 4 |
Not usually the clutch itself, it is usually the lack of an adjustable master cylinder or an incorrectly set adj master cylinder. |
its not the clutch itself. its a hydraulics issue. you're going to need a new master and/or slave. i'd replace the slave first. they're more prone to going out then a master. |
Correct its not always the clutch. But if you are already paying the labor for a slave swap, then its also a good time to swap the clutch. |
Have you tried bleeding the system yet? I had this same problem a while back and bleeding the hyds. made a big difference. |
Good luck getting it up bro, hope it's not down for a long time. |
RAISE the dead-thread... What happened? |
Yeah, I've got this exact issue. Believe it to be the slave. Pedal is firm, will shift in to gear with the engine off but not with the flywheel turning. |
I have the same thread!! I have the exact same car with the same problem! It happened to me about two weeks ago, Ive allready bleed the system, but no fix! I ordered a new master first, I dont want to have to pull the tranny if i dont have to but i am pretty sure its the slave cyl an throw out bearing not pushing the clutch at all. I started my car with it in gear ( I know its not good for the transmission at all ) and the clutch seems fine its a hydraulic issue! Let me know how it works out for u!! |
My problem was the clutch. Something came apart. Should be getting the car back tomorrow with the LS2/7 setup. |
© 2024 MH Sub I, LLC dba Internet Brands
