LS7 clutch in C6 problems
Now that its all back together, the clutch is still not disengaging properly. In order to engage reverse, we have to shut the car off and put it in reverse.
So, the drivetrain was dropped, clutch was re-bled, and same ****.
Anyone have some input here?
We're lost as to what to do next.
Is there something we're missing when installing an LS7 clutch in an LS2 vehicle?
The master is brand new as well.
TIA
http://www.gtoinfo.com/index.php/topic,13182.0.html
On a side note I always clutch in, put my shifter into first, then put it into reverse and it seems to make things a little smoother. I don't know how bad your problem is but I know as the LS7 breaks in the engagement point movers higher on the pedal. I also remember that the clutch was real grabby down low when first installed making think it was barely disengaging until it broke in. Good luck.
I have dropped the tranny 2x and have even replaced the master too. Same **** the clutch doesnt fully disengage.
I cant drive the car.
I'm wondering if I should try an adjustable master. Or i should give up and install a oem replacement.
BTW, i tried the adjustment as noted on the link above, didnt help.
Tell me. what are you going to try next, i am outta time and honestly have kinda given up on and LS7.
Wish I have never have gone with it.~!~!!!!!
Of course the worst thing that can happen is you have a clutch that doesnt disengage without a real solution to fix it.
Not to mention, guaranteed low enagagement for the first 500 miles. and possible endless bleeding of the hydraulics,
Did i mentioned having to drop the tranny more than once to double check your work.
My advice would be if your ok with all of this then yes try it.
iF you must have your car back that same weekend, go with something proven to be installed without countless install issues.
I would of rather of had a clutch known for possibly failing under hard abuse than a clutch that has not been able to work period from the get go.!!!!
So yea I wish someone would of told me. In a heartbeat I would have reconsidered.
Was the LT1 a cable drive? I liked the feel of my LT1's clutch.
Cuz I cant start it in 1st without the car jumping forward.
And you drove it like that for 300 miles?
i just changed my clutch friday, installed LS7, great clutch, but GM set-up is pain in the rump!
EDIT: After you think that you have bled it enough( I went through pretty much a whole bottle of brake fluid), just get in the car and start pumping the clutch pedal. I pumped mine for a good 15 minutes at least. After about 15 mins, start the car and try to get it in to gear. If it still won't and you still have a really soft pedal, continue to pump the pedal until you do get some pressure. Eventually, you will get some pressure unless you have a leak somewhere. DON'T RE-BLEED after you have done all that pumping, because you'll just have to do it again
