slave cylinder ?????
Old Feb 14, 2007 | 06:01 PM
pro2low's Avatar
Default slave cylinder ?????
anything i should know before i put my new slave in? or should i just bolt it in? first timer here
Old Feb 14, 2007 | 10:46 PM
chuckyt1's Avatar
I'm putting in all new hydraulics. The master comes pre-bled but I hooked the whole system together, (master and slave), and bench bled it before I put 'em in. Still haven't put the tranny in yet 'cuz it's so cold here, but I'm hoping it cuts down on the bleeding afterwords.
Old Feb 14, 2007 | 11:07 PM
pro2low's Avatar
yea i put it in......i solved the bleeding situation by buying the bleeder extension from steve d its a 35 inch line you run into your engine bay. so you can bleed the whole system from there. im in chicago too freezing my *** off in a heated garage haha. the floor is soo damn cold!
Old Feb 14, 2007 | 11:16 PM
chuckyt1's Avatar
Sounds good. Where did you get that extension? I migh need one of those. My garage is not heated, (@#$^&) so the tranyy sits, and sits and....
Old Feb 15, 2007 | 02:15 PM
pro2low's Avatar
his name is steve-d he is a member on here. i believe it was 89.50 shipped. i got it about 5 days later. where at in chicago are you?
