shifter problem
Old Feb 15, 2007 | 08:48 AM
z28camarofn's Avatar
Default shifter problem
Does anybody know why sometimes when I try to shift into 1st gear the shifter only goes in part way? It also did it when I was trying to go into 3rd. I have the clutch pressed in all the way so I dont have a clue what it is. The brake fluid reservoir next to the main brake fluid is full and the transmission fluid is good.
Old Feb 16, 2007 | 12:19 AM
michaelg589's Avatar
I have the same problems sometimes. When the transmission is really cold, I can't get into first at all. I have to shift into whatever gear it will shift into, then go to first. But it did it for first gear sometimes even when it was warm. I just put it in nuetral, left the clutch out and pushed it back in then shifted into first. It will actually explain that in the owners manual.
Old Feb 17, 2007 | 11:28 AM
1cleanbird's Avatar
do you have an aftermarket shifter? if so, I had the same problem. There are two screws on the top and bottom of the shifter, the top one came back to far, stopping the shifter to fully go into 1st, 3rd, and 5th. That's proly it. I was freaked out it was a synchro or somethin.
Old Feb 17, 2007 | 05:42 PM
LILWS6's Avatar
i get that in reverse and first mostly i've heard its a common thing. and that your supposed to put it in neutral and let the clutch out and then try and get it into tird always works for me.
