which adj master cylinder.
Old Feb 25, 2007 | 10:42 AM
TX_SS's Avatar
Question which adj master cylinder.
which one should i buy? ram?? mcleod?? any suggestions?
Old Feb 25, 2007 | 07:15 PM
P Mack's Avatar
The advantage of the mcleod is that it has a larger bore so you can have a shorter pedal travel to release the clutch. Unfortunately mine went bad within a week and many other people have had bad experiences with them too. Some people have no problems though. I've never had the ram.
Old Feb 25, 2007 | 09:09 PM
JonB's Avatar
Most just seem to stick with the stock gm. I looked at the ram only because it was like $10 more but after some searching on here most just stick with the stocker as did I.
Old Feb 26, 2007 | 07:49 AM
TX_SS's Avatar
k.. sounds good. ill stay with stock ones
