cluch sticking
Old Mar 1, 2007 | 11:43 PM
sarroyo's Avatar
Unhappy cluch sticking
I have a 2000 WS-6 and whenever i race the cluch gets stuck when i hit 2nd gear and i have to pull it out then it works fine. i heard that the i need to purge the cluch because it has air in the lines if this is true how would i do that. thanks
Old Mar 2, 2007 | 12:03 AM
sidewayz28's Avatar
im not sure, similar to mine.. but mine goes to the floor after i punch it in a higher gear, and i need to kinda pump the clutch for it to get back to normal
Old Mar 2, 2007 | 12:42 AM
sarroyo's Avatar
Yeah thats what happens to mine the only diff is i dont have to pump it. Do you know what it might be????
Old Mar 2, 2007 | 07:56 AM
CamaroTrish's Avatar
ive heard it has something to do with the bore of the master cylinder... i replaced mine with a mcleod adjustable and put in a 2001 slave cylinder...works fine now
Old Mar 2, 2007 | 12:07 PM
sarroyo's Avatar
Cool thanks i'll look in to changing it out
Old Mar 2, 2007 | 12:13 PM
Tigws6's Avatar
Before you do that, though, you may want to bleed the lines to see if that corrects the problem. You can bleed from above using a special bleeder, or below (not sure where on that one). If there is any air in the line, this would get it out and may correct the problem.
Old Mar 2, 2007 | 12:21 PM
Justin00SS's Avatar
Do the drill mod.
Mine does this and I need to drill mod it.
