I wouldn't do a lighter flywheel. But its personal choice when it comes to that. |
they do make a lighter flywheel but for around $400 i could not afford it atthe time of the trans rebuild, new hydrolics, the clutch kit and the install or i would have got it |
idk i pulled mine out and readjusted the pressure plate because i hated how i couldnt shift fast and how it makes my normal around town shifting harder... definitly think all should be readjusted |
readjusted how? |
Originally Posted by 1LoudTA idk i pulled mine out and readjusted the pressure plate because i hated how i couldnt shift fast and how it makes my normal around town shifting harder... definitly think all should be readjusted I would never suggest messin with the pressure plate on this clutch kit. It comes already set-up from GM for direct replacement with no modification, shims or adjustment. If your having problems shifting its either the driver or your hydrolics. |
I've got all my stuff in, including the LS7 kit and I love it. It has the typical low engagement but as of now i've only got about 100 miles on it so i'm sure it will get better with some mileage. I actually like the heavier flywheel since I do alot of drag racing, I noticed the difference of the flywheel as soon as I started driving it.. you can tell it has more momentum. I noticed it is smoother at higher rpms as well. I've gotten on mine from a roll a couple of times and it shifts great and holds great, mine just smokes the tires all of 1st and 2nd on street tires, lol. I also have no other engagement issues, no chatter..etc. It feels like a brand new stock clutch, just tougher..haha |
I just placed a Order! |
i was chirping 4th |
i just ordered mine today when i got home from work :D we shall see i've heard alot of good about this clutch. I don't do alot of racing but i do go to the track every once and a while and i run my car hard. So far from what i've been hearing it should hold up fone for me |
I dont have many miles on mine yet as I have few days to get it out as its still snow up here in the Great White North but it feels great and is absolutely butter smooth |
salty dry roads make for easy traction breaks. I found that it's harder to chirp gears with LCA's installed. I like the added traction and the LS7 has been great for 10k now for me. |
Originally Posted by LS1Aggie09 have you guys noticed a difference in rev quickness with the new flywheel as opposed to the stock flywheel? i love how quick my car revs now but at 93500 on the stock clutch, its due. i have the ls7 clutch and ls2 flywheel sitting in my room with a new slave and t/o bearing but am having second thoughts after thinking about the heavier flywheel making the motor rev a lot slower and losing power. |
© 2024 MH Sub I, LLC dba Internet Brands
