Clutch Problem
Old Mar 10, 2007 | 12:02 PM
azmarkus's Avatar
Default Clutch Problem
A couple of days ago the clutch pedal started getting really loose and sloppy, so loose and sloppy that you could push it in 1/3 of the way before you'd get any kind of engaging. Fluid was low but not outrageously so. It's now gotten worse, really tough to get into gear, and when the clutch is completely down, the car wants to creep forward. I had the clutch replaced less than 10K ago so I'll be going back to the mechanic that did work; any words of wisdom as to what else to look for?
Thanks in advance.
94 Z28 M6
Old Mar 10, 2007 | 12:52 PM
delsold's Avatar
im having a similiar problem except my clutch pedal is only really loose and has no reserve when its freezing cold out. My resevoir was kinda empty so i filled it back up and the problem seemed to get a ton better.
is it time for a master and slave cylinder?
bump
Old Mar 10, 2007 | 08:50 PM
02silvaZ's Avatar
possible master and slave prob
