Clutch bleeding techniques
Old Mar 18, 2007 | 03:04 PM
SpdFrk1990's Avatar
Default Clutch bleeding techniques
Which one is the easiest and best do you think? Has anyone tried to push the fluid in through the reservoir with a pump? I have this bleeder and thought about doing it that way. http://www.sjdiscounttools.com/psv12-205.html
Would there be any issues bleeding the system that way?
Old Mar 18, 2007 | 05:16 PM
brad8266's Avatar
aint worth 100$, its easy to just raise the car up and crack the bleeder while you have a friend push the pedal.
Old Mar 18, 2007 | 05:17 PM
SpdFrk1990's Avatar
I alrdy have that bleeder so I would not be spending any extra.
Old Mar 18, 2007 | 05:20 PM
brad8266's Avatar
Well in that case try it out then. I personally would just do it the old fashioned way though.
Old Mar 19, 2007 | 08:03 PM
3.4camaro's Avatar
get a buddy in the car and tell him to push the pedal down.
then open the bleeder
then close the bleeder.
and that should be all you need to do.
