Clutch info....???
Old Sep 23, 2002 | 07:10 PM
2001CamaroGuy's Avatar
Default Clutch info....???
I was looking at this post:
https://ls1tech.com/ubb/ultimatebb.p...=003939#000002
Next to last response talked about the RAM Clutch:
Part #s RAM-402 (Pressure Plate) and RAM-6130 (Clutch Disk)
I looked at Summit, the Diaphragm is an 11", 3,000 lb and the disc is 11" x 1 5/32" -26 spline.
Also, on Summit, there was a Centerforce Clutch:
Part # CTF-DF017010 that is supposed to fit LS1s but its demissions are 11" diameter,1 1/8" 26 spline .
What is the size of the input shaft? Am I thinking correctly saying that any pressure plate and disk that have that has either of these demissions will fit an LS1?
Thanks
Chris
<small>[ September 23, 2002, 08:46 PM: Message edited by: 2001CamaroGuy ]</small>
Old Sep 23, 2002 | 08:44 PM
Default Re: Clutch info....???
Any idea if this clutch would work on an LS1?
http://www.ramclutches.com/Products/assault_weapon.htm
With this kind of clutch, do I need a flywheel or is it built into the unit? Any idea if it would work with the 2001 slave cylinder?
I'm building a road car and want the lightest weight setup I can get. If I use a "standard" style clutch, I will install an aluminum flywheel.
Old Sep 24, 2002 | 10:13 AM
come on....someone must have the information I need <img border="0" title="" alt="[Sad]" src="gr_sad.gif" />
Old Sep 27, 2002 | 10:13 AM
MIGHTYMOUSE's Avatar
i don't know ram stuff but it looks like you have the right part numbers there for the base set-up.. i have a spec clutch email me if you want more info on that.
that drag clutch will definitely not work in your second post..
lastly.. dont get an aluminum flywheel.. it will hurt more than it helps.
