Worn Blocker Rings
Old Mar 31, 2007 | 05:42 PM
A-Dub's Avatar
Default Worn Blocker Rings
What do worn blocker rings look like? I tore open my T56 today to replace the blocker rings and upgrade some parts because I was having what I thought were synchro issues. The only bad part I could find in the trans were the 5-6 fork pads. All the sliders look good, as do the blocker rings but Im not sure what to look for on the blocker rings. Just wondering if this rebuild is going to fix my problem.
Problem is grinding into 3rd regularly and sometime 2nd and 4th, but only under low rpm. I bought new cf blocker rings, billet 3/4 keys, bronze pads for 1-4 and a new 3/4 fork.
Old Mar 31, 2007 | 08:52 PM
Steve Gunn's Avatar
Rebuild it and see.... I'd upgrade your clutch hydraulics for good measure While you're in there.
Old Mar 31, 2007 | 09:12 PM
A-Dub's Avatar
Yea great response, I have no clue, but spend money. Money fixes everything
Old Mar 31, 2007 | 09:32 PM
ls1 joe's Avatar
You can measure the distance between the blocker ring and synchro ring on the gear. If it is less than .030 replace the blocker rings. What you are discribing is a blocker ring problem and they should be replaced.
Thanks,
Amber
Old Mar 31, 2007 | 09:57 PM
A-Dub's Avatar
They are being replaced regardless, I was just trying to make sure any transmission problems are addressed while its apart
Thanks
