T56's are junk, please help.................
If you think about it, it makes perfect sense, new parts (synchros, gears, forks ect) keep getting put in these transmissions and they keep blowing these parts up. DUHHHHHHH obviously its not the internal stuff!!! <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" />
And people keep saying "well its been made since 98...." THAT DOESNT MATTER. If they have a tooling/machining probelem or whatever that goes unnoticed for a period of time, that has nothing to do with how they were made before. Maybe they tried a new process and within the last year at the plant? who knows. All I am saying is that an out-of-spec casing seems like a very very logical explanation.
The only thing that will tell if a new trans fixes the probelem would be to get a new trans. I bought a brand new car and i want the ***** fuka to work properly. 1-3k miles per trans is BS.
<img border="0" title="" alt="[Smile]" src="gr_stretch.gif" /> <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" />
<img border="0" title="" alt="[Confused]" src="images/icons/confused.gif" />
It is nothing new, guys.
- 3-4 shift forks
- 3rd gear synchros
- getting stuck in 4th
- wont go into 1st sometimes
those probelems listed above are showing up alot in the 01-02 cars, i mean alot. There is something wrong with the 6 speeds from the last year and a half, that is what i am getting at.
(ill still take the m6 anyday over the 4l60e!)
<strong>Maybe somebody could help me out here, whenever i'm at the drag strip, or even on the road i'll hammer it in 1st, shift it to 2nd(wheels spin), and try to go to third it wont, the clutch will stick halfway down and I will have to pull it up with my foot to get it in, I have to coast to the finish line at the strip because of this(1/8). Any help would be great?</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Do a search for "DRILL MOD"
1 - A mechanic on a race team that has used this trans
2 - Has built a multitude of them
3 - Tracked down the problem with the tech assistance of Tremec themselves
There is an issue with something other than internals as they were all replaced 3 times. It's not shifting tech as I was very easy on the trans and the amount of press used during shifting. My tranny has NEVER been powershifted. During the attempt at the last rebuild he showed me the internals and there was stress placed on the parts with no show of wear at all.
Take it for what it's worth but there is a manufacturing defect with thes trany's from Tremec.
<strong>Its obvious the "tremecs" arent holding up as well as the LT1 counterpart "borg warner" units. But, there was not a rash of people breaking their 98-00 T56's, with probelems like
- 3-4 shift forks
- 3rd gear synchros
(ill still take the m6 anyday over the 4l60e!)</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">I'm glad someone else has noticed this. You simply do NOT see the same number of complaints coming from those with 98-00 t56's as those with 01 and 02's. In my opinion, *something* changed somewhere before or during the 01 model year. I can use up all my fingers (and some of my toes) counting all the people I know with 01's and 02's who've had the tranny problems mentioned above.
Later,
Drew
'00 Formula WS6 <-- 26k and no tranny probs!
<strong> </font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by RED QUASAR:
- 3-4 shift forks
- 3rd gear synchros
Later,
Drew
'00 Formula WS6 <-- 26k and no tranny probs!</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Dude, you're definitely right, but they were crappy to begin with; they're just even more crappy now. I've still heard more than enough cases of earlier LS1 T56's going kaplooey to convince me that in general, the LS1 T56's suck *****. Maybe more so in newer years, but still. I think most of the smart (yet very gay) 6-speed owners have turned to the dark side of the Tranny Force and just decided to throw an automatic in their car and be done with it. Also, some of us are more abusive than others. <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" />
<small>[ October 09, 2002, 12:46 AM: Message edited by: RAGEman ]</small>
However, powershifting is a known way to break a transmission even if you are doing it right. My 88' TA has the World Class T5 that Irebuilt with Motive Gear parts when I put the 300hp 350 in the car and has never once gave me a problem in the 5-6 years it has been behind the 300hp 350 and I speed shifted it at least 1-2 times every couple days. I powershifted it twice in its life and thats it and took it to the track once. Either the tranny is much stronger or the way I drive it kept it from going out...including the synchros. I'm thinking the clutch and shifter stops are our big problems.
If the car is under warranty get it fixed somewhere else and have GM pay for it. If they say no call BBB and go through that crap and get them realizing that you are seriously tired of the crap and they need to do something different b/c the factory rebuilds aren't fixing the problem. There is a process that you can go through to get GM to pay for the repairs and I believe is similar steps to going through the lemon law process, but instead you keep the car. After 3 times I wouldn't even fool with the dealer again but take more drastic measures.
Knock on wood also but mine has 5500 miles on it with no problems other than my rear-end whine nightmare I went through.
<strong>I just had my 02 replaced under warrenty. It was the 3rd time it has been out of the car in 5500 Mi. It was my trans that the machining was off on. It's NOT dealer crap as the guy who rebuilt it before replacement is;
Take it for what it's worth but there is a manufacturing defect with thes trany's from Tremec.</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Kobwo, I'll be getting in touch with you via email when i have some time. I want to have a full arsenal when i attack the dealer.
I'll be taking mine in for the 2nd time. I currently have exactly 5500mi on the car right now. What I want to find out is, has tremec corrected the probelem since, so that if I get a brand new trans (completely new) how am I to know that the casing doenst have the same defect.
hmmm we'll see.
<img border="0" title="" alt="[Wink]" src="gr_images/icons/wink.gif" />
<strong>Dude, you're definitely right, but they were crappy to begin with; they're just even more crappy now. I've still heard more than enough cases of earlier LS1 T56's going kaplooey to convince me that in general, the LS1 T56's suck *****. Maybe more so in newer years, but still. I think most of the smart (yet very gay) 6-speed owners have turned to the dark side of the Tranny Force and just decided to throw an automatic in their car and be done with it. Also, some of us are more abusive than others. <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" /> </strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Speaking for the smart and gay LS1 community that has switched to an auto, there is another reason to switch trannies - you don't break OTHER parts of your car as much. Was the reason I switched. My T56 was holding the power well, but clutch issues were never fun and the second gear synchors were only a matter of time from going boom.
Greg
I've been crying since day one that 98+ Fbody 6spd's are SH|T compared to the 6spd's in the LT1's.
I've driven MANY LT1's. . . all of them shifted like butter!
In any case, they tried to rebuild mine ~3 times by 30k miles. . . FINALLY the dealer asked for a new one. . .
All felt fine on the drive home, then it popped out of 3rd. I called the dealer and had him check it out. . .
They replaced the tranny w/ a new one.
I have 40k miles on this one. Still feels like **** compared to LT1 trannies. Heck, my friend has a rebuilt one w/ the "Road racing" option from a popular T-56 rebuilder, and that feels like **** compared to the Stock tranny LT1's I've driven.
I've hopped in 98's & 99's on dealer lots w/ low miles & they felt like ****.
I've met MFBA members w/ new SS's & Firehawks and I drove or felt them , and they sucked.
<strong>I've been crying since day one that 98+ Fbody 6spd's are SH|T compared to the 6spd's in the LT1's.
I've met MFBA members w/ new SS's & Firehawks and I drove or felt them , and they sucked.</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">:lol
I think we can come to a general concensus that the LS1 M6 sucks!!! <img border="0" title="" alt="[Mad]" src="gr_images/icons/mad.gif" /> :lol
<strong> </font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by mgreen:
I think we can come to a general concensus that the LS1 M6 sucks!!! <img border="0" title="" alt="[Mad]" src="gr_images/icons/mad.gif" /> :lol</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">BINGO.
Yout tremec T56's are made in Mexico. Been that way since late '97. The LT1 T56's took MAJOR abuse without problems.
<strong>Speaking for the smart and gay LS1 community that has switched to an auto, there is another reason to switch trannies - you don't break OTHER parts of your car as much. Was the reason I switched. My T56 was holding the power well, but clutch issues were never fun and the second gear synchors were only a matter of time from going boom.
Greg</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Yeah, thus the use of the word "smart" in my post. You're preaching to the converted. However, I take pride in my straightness and won't be converted to the dark (auto) side.
