Trany and clutch master?
Old Apr 15, 2007 | 11:13 AM
KilerTA's Avatar
Default Trany and clutch master?
I had my Slave clynder go out on me a month ago when i was starting to shift into second and the trany was completly rebuilt about 4-5k ago dont reamber off the top of my head well i replaced the slave and i know some say that you need to replace the clutch master after a slave install but my question is when i got to shift into second or 3rd it wont allow me to shift into gear it feels like its hitting a brick wall untill i go back under 5500-6k i shift at 6800 but since the trany is completly rebuilt i wouldnt think it was the trany is there a chance that the clutch master is getting some sort of blow by when it being put under higher rpm shifts hopefully this makes since and someone understands
Old Apr 15, 2007 | 11:48 AM
JonB's Avatar
I would try bleeding the system so more. If there's air in the line it will do just as you described. If bleeding does't solve it then go to a new master. If you did't have this problem before the new slave I would guess that its just air in the line.
Old Apr 15, 2007 | 12:05 PM
KilerTA's Avatar
Not only did i do the bleeding but i had a shop do the bleeding since i thought i was a concern and they dont know what to think them selves
