clutch problems!
So a day ago I'm out cruising because it is nice out. Driving around town, stop and go and dont get over 35mph. After about a half an hour/45 minutes of driving, the clutch starts to chatter a lot and engage/disengage higher up on the pedal than normal, right before you take your foot off of the pedal. When it started to do this, I stoped and had a quick bite to eat for about 30 minutes. when I returned to the car to drive it again, the clutch did not chatter and the pedal went back to a more normal engagement point. It seems like this problem was directly related to the car/trans getting hot because after it sat and cooled for a little bit, the problem stopped. Any Ideas of what a problem might be or any experience with a similar problem?
Background info: car and mods are in sig. The clutch is a RAM replacement clutch, rated at 400hp I believe. The clutch has a little over 1000 miles on it and is well broken in. I bought the car from the previous owner who installed the clutch and the mods. Maybe he didnt bleed the slave cylinder properly? Any Ideas?
