Problem removing master cylinder
I've been able to get the u-bolt out, thinking that it'd make things easier but no dice. Plus, the reservoir doesn't seem to fit behind/underneath the brake booster, I can't swing it around the front because there seems to be a metal clip on the bottom of the booster holding a big-*** wire loom.
I've been tempted to pay one of the 12-year-olds in the neighbourhood to help me out, my big fat meathooks do not help this task one bit.
Is there something stupid I'm missing? Enough of you have successfully pulled this off so it's gotta be something I'm doing wrong.
the resevoir can be "manuvered" in the gap between the booster and the bracket, just play with different angles, the trick is to ensure the rubber line is on the other side of the booster, just play with the cables and hoses until you can shove it to the other side.
Pull the braided line out of that area so that way it's pretty much within view of you. Once done, you should be able to manuver the master out by just playing with the angles. The master itself has lots of play with the connecting rod so don't be afraid to compress and bend and manuver till it comes out.
Thanks for the input!
