replaceing clutch does flyweel need to be resurfaced?
Old Apr 30, 2007 | 11:07 AM
2000ws6transam's Avatar
Default replaceing clutch does flyweel need to be resurfaced?
well i had a leak in my rear main seal that put some oil on my clutch and lead to its 6K mile demise if the flywheel only has a few hot spots is it sandable or are there any options to not haveing it resurfaced?
Old Apr 30, 2007 | 11:32 AM
Tootall's Avatar
put a straight edge on it, see if it's "level" It should be flat all the way. If it is, you can use a sanding disk, or a scotch disk, or resurfacing does all of this.
