NEED HELP BLEEDING HYDRAULICS!!!!..please
Old May 5, 2007 | 06:52 PM
blacksskid07's Avatar
Default NEED HELP BLEEDING HYDRAULICS!!!!..please
Ive been at this with my friend for about an hour. The cap and rubber are out of the resivour (sp) and he's pumping the clutch a few times and then pressing in as I loosen the bleeder then tighting it again. It will get a little form and the next time all the way to the floor. I have no idea whats going on and I just want to drive my car.....please save me
Old May 5, 2007 | 07:27 PM
please...any1
Old May 5, 2007 | 09:08 PM
I went from a ls1 to a ls7 clutch do i need to adjust the pdeal or anything to get the pedal firm??
Old May 5, 2007 | 10:17 PM
Mike44138's Avatar
No you shouldn't. It can just take a long time. Start by opening the bleeder while your friend keeps the reservoir full. When you start getting a steady stream of fluid close the bleeder. Have your friend get in the car. Open bleeder, depress pedal and hold, close bleeder, repeat. If you get air stuck in the master it's very possible that the only way you'll be able to get it out is to bench bleed it.
Old May 5, 2007 | 10:37 PM
how to I bench bleed it? and we're still go gona back at it for a lil while cause there's still some air someing out everynow and then
Old May 6, 2007 | 12:15 AM
balbosky01's Avatar
Just keep bleeding, some ppl here have mentioned that it has taken them more than an hour to bleed the system, it took me like half an hour to do mine.
Old May 6, 2007 | 12:58 AM
I just finish bench bleeding the master with a friend...whch did have alot of bubbles. Now it's time to put it in and so 2nd round with the bleeding lol.
Old May 6, 2007 | 02:32 AM
allright so
we've been at this allll afternoon/night/ and now morning
we even bench bled the master
i have no idea if air is coming out
THE PEDAL WILL NOT FIRM UP!!!!
it's going to the damn shop
Old May 6, 2007 | 05:30 AM
gforcejunkie's Avatar
im having the same problem right now. all except mine never gets firm.
Old May 6, 2007 | 05:57 AM
01Z28M6's Avatar
I would have to start thinking the clutch master or slave cylinder has gone bad.
When I did the drill mod I just hand pumped clean fluid through the cylinder and line. I then topped off the reservoir and put the whole thing back on the car in one piece. I attached the cylinder to the firewall, snapped the line into the slave through the bell housing and was good to go with no bleeding at all after that. I realize the difference with you is that you have had the slave cylinder off and disconnected whereas I only had the master out.
Old May 6, 2007 | 08:28 AM
vettenuts's Avatar
Have you tried using a Miti-vac on the master to see if that clears it?
Further information
Old May 6, 2007 | 10:49 AM
idk and the slave is brand new. I'll drop it off at the shop tomorrow and say the magic words "fix it"
Old May 6, 2007 | 05:52 PM
Derek_02's Avatar
I just had to go through this today. We went at it for about 1.5 - 2 hours and finally got the clutch to work. The peddle still feels really soft but the more i drive it the better it's getting. Eventually yours should get better too. Lots of luck.
Old May 6, 2007 | 06:47 PM
ghettocruiser's Avatar
Another option for you is to try the Motive Power Bleeder. I bench bled my new master cylinder today after doing the drill mod and swapping in an adjustable rod. Worked perfectly, and I suspect it will work perfectly when bleeding/flushing my entire system after I re-install it in the car.
Here is a thread with user feedback and part numbers...
https://ls1tech.com/forums/showthrea...motive+bleeder
Justin
Old May 6, 2007 | 09:11 PM
thanks guys
I don't know what the hell is wrong with the hydraulics it will engauge and the new clutch and everything works fine. The pedal will not get firm enough for me to really be able to drive it. The damn this is pissing me off. It's at the garage right now and will go up on the lift in the next day or so. Couls be a fucked up slave or the master went bad which was fine before all this bs started.
My mechanis can bleed it more
power bleed it
or replace the master and ANOTHER slave which I can do in my garage. Looks like im going to be playing labor for once
Old May 6, 2007 | 09:15 PM
I'm not even going to start on about how the started died on the way to the shop. I think this car might make me just cry. It's pissed my dad and me off so much I'm no longer putting a cam in it. I have new seats coming, stainless inserts for the back, and then i'll do true duals, and fix my tint and I am done! until the winter.
Old May 6, 2007 | 09:53 PM
Derek_02's Avatar
Man i feel you pain. Your story sounds exactly like what i was going through all weekend. I wanted to do a cam and stuff but now i to am at the point where i say f*** it, i like driving it a lot better. So that idea is out the window unless i decided to pay some one else to do it. I feel real bad for you and hope everything works out good. These things can be a bitch sometimes thats for sure.
Old May 6, 2007 | 10:01 PM
Too mad im almost 19 and there wasn't any last night
^^^^That's me all day and last night lol
And I'm only a 18 1/2 yr old kid but I am really good and know what I am doing aith these f-bodys. This isnt my first time working on one lol. But I'm in over my head and this is killing me I just want to drive it. The battery or the Alt. could have gone dead not really sure.
Old May 7, 2007 | 09:32 AM
s10-den's Avatar
sit back,drink a cold one(pepsi) and relax......it happens the best of us!!I was bleeding mine one day,went through 3 cans of fluid when i relized something is wrong,turns out the slave went bad.Was not a damn thing wrong with it befor,I was just changing the clutch!something to think about and yes i have bought them brand new and wasnt worth throwing in the bottom of the ocean.
