master and slave cylinder
sooo
Are Ram's adjustable master cylinder and slave cylinder's any good?
Would a a 50$ advance auto slave be a pos, thanks
But I would put a quality GM one in IMO. I like to do it once & not gamble.
The ram master is good. it is a stock one made adjustable. I would do the drill mod as well.
Just for some info. So if you buy a RAM now, you wont have to pay that much for another one in the future. Just get a stock GM one and swap the rod. Another thing...the RAM master didnt have the internal stop cut on mine. Which I thought had to be done for the ADJ. to be effective. Not sure about that...but I only use the adjustment because Im in a swap car and the pedals arent exact to the 4th gens...
Either way...I say go with the GM slave, and RAM master.
Justin
https://ls1tech.com/forums/manual-transmission/317767-stock-adjustable-master-cylinder-writeup.html
