power bleeding question
Old May 8, 2007 | 05:14 PM
slowscott's Avatar
Default Please help! power bleeding question
I'm in the middle of trying to power bleed my clutch hydraulics. I pumped it up to just over 10 and when i went in the car and stepped on the pedal it went right to the floor and wouldn't come back up. I pumped it a few more times using my hand because the spring wouldn't let it come back up. I can build some pressure if i disconnect the mity vac and pump the pedal over and over. What am i doing wrong? I thought this was suppose to be easier than the normal way of bleeding?
thanks
Old May 8, 2007 | 06:50 PM
slowscott's Avatar
does the master have to be bench bled first?
