adjustable rod?
Old May 23, 2007 | 05:30 PM
prairieArrowLT1's Avatar
Default adjustable rod?
has anybody every had to make an adjustable rod to engage an aftermarket clutch? I have a Bully stage 2 and the shop has lengthened the rod by almost 2 inches, but the trans still does not work right. has anybody every cam across this before?
Old May 23, 2007 | 11:13 PM
wrencher's Avatar
wrencher
Yes I have, it was in situations where nothing worked.
Sure you dont have a hydraulic issue there?
Does the pedal still have alot of freeplay in it or mushy?
Old May 31, 2007 | 05:59 PM
Whoa , the adjustable rod worked, Its Alive!!!
Old Jun 2, 2007 | 08:52 AM
RE AND CHERYL's Avatar
If you've lenthened the rod by 2" I gaurentee the master cylinder piston does not fully release when the pedal is up.
