Clutch not disengaging
my car was in a wreck before i bought it. it was it pretty on the front driver side. the frame was still good so they just replaced all the broken parts. the problem is though that not the clutch isn't disengaging all the way. Ive tried to diagnose the problem but was unable to come up with a solution. the back of the pedal isn't hitting the firewall or anything and I have check the hydraulic system. I'm fresh out of ideas, anyone here have any for what i can look for or anything like that?
Either way you got some work to do. Unless you want to pay and get the full system replaced.
Clutch plate and kit with all hydraulics.
I had the same problem with My stock clutch after a wreck.
After much fussing I pulled it out and found the adjustment cam on the pressure plate set to full tight. I'm working the problem now.
I dont have any idea if you have the same clutch as me. Mine is a '04 cts-v
LS6 T56 with 16000 Miles
what the S/B and the serv. manual does not tell is that the pressure plate must be suported by the housing (where the bolts go) not the plate face when you press the fingers.
hope that helps.
