Clutch problems please help
2nd gear shift is ok, third gets stuck halfway in sometimes and 4th gear is notchy...
I don't slip my clutch much at all, and never race it. Also, 5th and 6th gear almost never give me any problems. Is this because the difference in gear speed and input shaft speed is less and the non-disengagement of the clutch is less noticible,
or do I need a rebuild?
Ranger
I Did The Drill Mod And It Didnt Help. It Worked For About 10 Shifts Then Faded. Every Time I Bleed The Clutch It Works For A Short Time. It Got To Be The Fluid. Its Pissing Me Off.
The design of the LS-X puts the slave inside the bell housing. Until that design changes, the fluid is going to get cooked quickly if you drive aggressively.
Ranger
Ranger
If Rangers method makes my car work for fifteen minutes and then goes back to ****, what does that mean; WWWAAAYYY too much heat in my clutch fluid?
and follow the protocol exactly. Then post your results.
Ranger
Ranger
