clutch replace Q???
my question is what all do i need to replace i know the throw-out bearing but do i need to get a new slave as well?? i've also been having trouble with the clutch pedal sticking to the floor, heard about a drill mod i can do but dont know what it is... the car is an 02 with 66k.
please help
daniel
The drill mod is when you drill through a restriction inside the stainless line that conneccts the master cylinder and slave cylinder. It is on the master end, which means the master has to be taken out so you can get the line off of it.
Hope I could help.
I replaced all of this stuff at once and i havent had a single problem since. I suggest this procedure to anyone.
o well its all in due timethanks for the help guys
