Ram Adustable master Problem....
Old May 31, 2007 | 08:49 PM
SSPerformance's Avatar
Default Ram Adustable master Problem....
Just did a clutch in a friends car not the frist clutch o ever did or master cly swap...... ive always used Mclouds and never had a problem. I have the Ram master Adjusted as far out as i can to get as much thro... no more adjustment left. I bleed it like crazy went thro a big bottle of brake fluide... even tried gravity bleeding it and still it dose not fully release the clutch it stills dosent wana go into gear its that bad.... car has a very very good pedal im thinking this ram isent gona work with the Spec stage 2 plus?..... about to order a mcloud for it
Old Jun 1, 2007 | 07:25 AM
teke184's Avatar
did you use the slave spacer?
or at least one came with my Spec 4.
Old Jun 1, 2007 | 08:00 AM
brad8266's Avatar
You may need the slave spacer.
BTW man, that spec 3+ is working out great for me.
Old Jun 1, 2007 | 07:14 PM
yes i have the spacer behind the slave
Old Jun 5, 2007 | 07:35 PM
put a McLeod master in it and problem fixed
