trouble bleeding clutch
Did you try to bench bleed it first? Thats the best way to get things started. The slave seals itself off as soon as you unhook the disconnect. So it shouldnt loose too much fluid. If you bench bleed the master, in theory the only air in the system will be in the disconnect fitting area. Shouldnt take more than a couple bleed cycles to push that out.
When I did mine, I bench bled with a motive power bleeder. And also did a few pumps by hand. When I installed it back onto the slave, I had pedal pressure instantly. I bled it some more anyway just to be safe. Ran some fluid through with the motive power bleeder, and bled it a couple times the manual way. No problems. Went super easy. So easy that I thought something was wrong.
Bench bleeding is key..
Justin
