Problems getting tranny back in (t56)
I've also done this 3/4 times...1st time i almost cried when i spent over an hour trying to get it to align up
I know it was in the darn splines we put wrench on crank pulley and turned engine and the tailshaft of tranny output turned. We even tried putting driveshaft on back of trans and turning it. We tried to level the engine with jack, the tranny with jacks and we were paranoid about letting tranny hang .It was a nightmare .We spent hours two of us trying to get the tranny to go in 100% and it never did!
I put bellhousing on first. Finally said heck with it. Got longer bolts and pulled it in evenly I still think the darn spring pressure on the slave against the pressure plate was keeping it from going. The clutch seems to work ok and we didnt' break off any ears. So you are not supposed to pull it in but whatever I was not going to be there forever. And already retightened the darn discs a couple of times enough is enough.The plastic too might suck but it had to be in there reasonably close.
I am not going to lose any sleep that wrecked anything.But the job is a lot easier on an overhead.Doing it on the ground like I did really sucked.
