Gear safe cleaning solvent?
Old Jun 19, 2007 | 12:49 AM
heimbo's Avatar
Default Gear safe cleaning solvent?
I'm rebuilding a t56 and keep seeing in the Tremec manual to clean everything with "solvent." What type of cleaner are they referring to? Brake clean? or do I need to use something more mild for the various materials?
Any help is much appreciated.
Old Jun 19, 2007 | 07:53 AM
wrencher's Avatar
wrencher
Brake clean works just fine. just make sure the trans is not dry for it's maiden voyage after the rebuild.
Old Jun 19, 2007 | 09:27 AM
CTSmechanic's Avatar
I'd buy a case of brake clean.. and a little squirt can and fill it with ATF so when your assembling the thing you can lube all the parts up.. I use one filled with 90w for the tranny I build although there not t56's
