Bent 3/4 shift fork? (search not working)
Old Jun 19, 2007 | 12:27 PM
Gauge's Avatar
11Second Club
Default Bent 3/4 shift fork? (search not working)
Hey guys,
I can't search for a thread that lists the symptoms, and I want to verify that I have a bent 3/4 shift fork. A few weeks ago at the track my car got stuck in 4th at the end of the track. I managed to get back to my spot, parked, and fiddled with it. I ended up slapping the shifter a few times, and it came out of gear. So, I drove a few minutes, and everything was fine. I had no troubles for the rest of the day.
Since then it's happened 3-4 more times, and every time I gave the shift **** a few slaps, and it would pop out of 4th. Today coming back from lunch, it happened every time I let the clutch out in fourth. If I sat at a light shifting back and forth between 3 and 4, it was fine. As soon as I would let the clutch out in 4th while driving, it would be stuck. It's usually fairly easy to get it out of gear, but it does take a smack on the shifter stick.
I hear that the 3/4 shift fork is made out of some bullshit metal that bends easily. Do you think this is my problem?
Old Jun 19, 2007 | 07:32 PM
wrencher's Avatar
wrencher
No, it sounds like you broke the slider keys on the 3/4 synhcro though.
That is also common failure problem for them to get it stuck in gear.
but it really dont matter, you need a rebuild now anyway, I would sugest the new 3/4 fork, along with billet 3/4 keys & bronze shift fork pads.
(In addition to the standard rebuild componets)
Old Jun 19, 2007 | 10:30 PM
Gary Z's Avatar
The 3/4 shift fork is aluminum, as is the 1/2 fork. They are massive and obviously very strong. The fact that the Viper version of the T56 has a steel 3/4 fork suggests that it is possible to distort the aluminum fork but it wouldn't be easy.
Old Jun 20, 2007 | 09:01 AM
Gauge's Avatar
11Second Club
Well, on the way home yesterday it didn't happen at all. I guess I'll wait until it becomes critical since it's not my daily. Luckily, since it's the last gear I use at the track, if it does get stuck, I can deal with it after my run, and it won't affect my racing.
Good thing I have a GM service manual at home. Might be time for my first tranny rebuild!
