Why replace the master/slave when using and aftermarket clutch?
Thanks!
-Brad
Aftermarket units may have slightly different finger heights, and since the bearing itself is not adjustable, making the master adjustable allows you to control the release of the clutch. For instance, if the aftermarket unit had a finger position .050" lower than stock, the bearing may not travel far enough to make complete release of the clutch.
