Help with M6 pedal removal
Old Nov 2, 2002 | 08:02 PM
Cody99TA's Avatar
Default Help with M6 pedal removal
ok everything is unbolted and disconnected. the pedals are just hanging. the brake linkage is in the way as we try to rotate the pedal assembly counter-clockwise to pull them straight out.
i've been screwing with this for 2 hours now. any suggestions??
Old Nov 4, 2002 | 12:57 AM
John B's Avatar
Moderator
Default Re: Help with M6 pedal removal
Just take out he bolt that runs through the brake pedal and disconnect the clutch master cylinder linkage!
