Reverse issue
Old Jun 26, 2007 | 01:13 PM
NU_BLUE's Avatar
Default Reverse issue
Anyone have issues with their car "popping" out of reverse? Mine doesn't do it alot but it does and its annoying esp. on car w/45K. Anyone know what causes that?
Lucky, I live right down the road from T56 Rebuilds @ Hwy 6 in Houston.
Old Jun 27, 2007 | 05:16 PM
JUSTONY's Avatar
My car started doing it every once in a while and eventually it did it every time i wanted to put it in reverse and I had to hold it in place. I just got it fixed, one of the shift forks was bent. Wasnt that big of a deal to fix, but it was kind of a hassle
Old Jun 27, 2007 | 05:23 PM
ls1 joe's Avatar
Could be a fork or the reluctor ring on the slider. You could fix just it by popping the tailshaft housing off but if you are going that way do the keys, pads and blockers. It will save you time and frustration later on.
Amber
PS: It is nice to be close by.
Old Jun 28, 2007 | 11:43 AM
berger21's Avatar
Mine turned out to be just the shift fork pads. They are plastic and mine were pretty much gone. I replaced them and no problems.
Old Jul 1, 2007 | 04:41 PM
NU_BLUE's Avatar
......and this can be done w/o pulling the trans.
Or is this is just wishful thinking....?
If I have to have it pulled then I'll replace everything I can.
Old Jul 1, 2007 | 06:48 PM
ls1 joe's Avatar
You are going to have to pull it. The tailshaft housing will not come off if you don't.
Amber
