Trans is coming out again. #*^$!
Old Jul 1, 2007 | 01:18 PM
chuckyt1's Avatar
Default Trans is coming out again. #*^$!
1. Put in Tex clutch last summer
2. Pulled it again to replace the 2-3 slider.
3. Broke 2nd gear about a month ago, pulled it again.
Went to the track Friday to see what it might do. Short version - Hydraulic fluid coming out of the slot in the bellhousing and no pedal.
Less than a hundred miles on '02 GM slave
F#%K!!!
Old Jul 1, 2007 | 07:55 PM
chuckyt1's Avatar
Never mind... Bleeder came loose. Always check the easy stuff first!
Old Jul 2, 2007 | 01:46 AM
nvmy2000ss's Avatar
Did you pull the tranny to find that out? That would suck!
Old Jul 2, 2007 | 03:14 PM
chuckyt1's Avatar
Thankfuly - No... When I first got under there I pulled the MC line thinking maybe it was leaking. Looked it over and hooked it back up. Still had the fluid coming out of the bellhousing. I was about two minutes away from pulling the tranny when I thought maybe I should check the bleeder. Never seen or heard of this happening.
By Brett Foote | 2026-06-04 05:00:17
