VDS Shim thickness...?
Old Jul 23, 2007 | 10:12 PM
1cdub's Avatar
Default VDS Shim thickness...?
In a nutshell I'm running the Ram VDS clutch with the Sintered iron disc in the HOSS. Holds great, is easy to drive, no chatter, etc, etc....only problem is in dis-engagement. I've bled it to death, and adjusted the M/C all the way out and at 8000rpm it will still "creep" the car forward thru the lights even with the clutch all the way in...my question is what is a ballpark on shim thickness to start at? I called Ram and they said .150 ??? This seems extreme given the total travel of the slave. Anyone here played with shim thickness on this set-up?
Old Jul 27, 2007 | 04:15 PM
1cdub's Avatar
tryin' again..
Old Jul 27, 2007 | 05:39 PM
blk00ss's Avatar
Do you have an adj. master cylinder?
Old Jul 27, 2007 | 08:41 PM
1cdub's Avatar
Originally Posted by 1cdub
In a nutshell I'm running the Ram VDS clutch with the Sintered iron disc in the HOSS. Holds great, is easy to drive, no chatter, etc, etc....only problem is in dis-engagement. I've bled it to death, and adjusted the M/C all the way out [U]and at 8000rpm it will still "creep" the car forward thru the lights even with the clutch all the way in...my question is what is a ballpark on shim thickness to start at? I called Ram and they said .150 ??? This seems extreme given the total travel of the slave. Anyone here played with shim thickness on this set-up?
yes sir...hell my pedal is a good 3" above the plane of the brake pedal
Old Jul 27, 2007 | 11:43 PM
blk00ss's Avatar
LOL my bad I usually pay more attention than that. Do you not already have a shim in there?
Old Jul 28, 2007 | 05:28 PM
1cdub's Avatar
no shim yet..
Old Jul 29, 2007 | 01:09 PM
blk00ss's Avatar
Guess the only thing left to do is shim it...
