t56 problems
Old Aug 14, 2007 | 05:56 PM
badinfluencelsx's Avatar
Default t56 problems
im doing a 4l60e to t56 swap on a 99 silverado 4.8. i get everything lined up. the tranny slides in fine and hits a stop. the dow pins arent even touching yet but it is bottomed out. i tried to tighten it down and broke a bolt hole. the flywheel wont budge when i tighten the tranny bolts either. any suggestions?
any help is greatly appreciated.
if i cant get it today im takin it somewhere and havin it done. its a pita without a lift
Old Aug 14, 2007 | 09:07 PM
samdogmx's Avatar
are u sure the input splines are engauging with the clutch disc?
Old Aug 14, 2007 | 11:19 PM
yea i pulled it back and u can see on the input shaft where it pushed in a few inches. i put some lubricant on it and it cleaned it off a few inches so i know it went in that far.
Old Aug 15, 2007 | 10:34 AM
i guess i measured wrong.. the input shaft splines are already hitting the pilot bearing and i still need almost an inch.
Old Aug 16, 2007 | 01:45 PM
turns out i had the wrong pilot bearing..
